Can I use SNTP Port Forwarding with Hub One?
p_lep
I have Hub One, and would like to forward SNTP packets to my device.
Under Port Forwarding, I can't see any SNTP setting, only NTP Server and Time Server (NTP). I added both of these just to be sure, but I don't think it works.
Is it possible to use SNTP? I believe it is on port 123
thanks
Paul
Tags (2)
2 REPLIES 2
bobpullen
Fixes: 331
Re: Can I use SNTP Port Forwarding with Hub One?
You can create a custom rule that uses port assignments of your choice. You are not limited to the pre-populated services. That said, port 123 is typically used for NTP services.
p_lep
Thanks Bob.
After your prompt I spotted it under Manage Games and Applications/Add ...
As you say, using NTP already forwarding port 123 so my issue must be elsewhere, thanks
