Can I use HUB1 PSU with new HUB2?
bobw1943
I'm changing a HUB1 for a HUB2. Can I just plug the HUB1 PSU into the HUB2 ? It would save a bit of time and effort fiddling with wiring.
3 REPLIES 3
Fixes: 388
Re: Can I use HUB1 PSU with new HUB2?
Personally, I would use the new PSU - but it's up to you.
Fixes: 585
Whilst I would tend to agree with John, the PSU's are exactly the same spec. I don't use my Hub 2 much but in fact when I went to check them I discovered that the PSU I last used with the HUb 2 was in fact the Hub 1 one😀
greygit1
Read the details on the little black box. If they match, then it is likely it'll work without problems (if the details are correct).
