Can I replace....
markjonesx
Can I replace....
.....my BT Open Reach modem (the white box) & my Netgear Router with just one box?
What would you recommend? I need to gain a LAN port.
I currently unlimited fiber through phone line, FTTC then VDSL2+, I think....
12 REPLIES 12
HairyMcbiker
All Star
Fixes: 21
Re: Can I replace....
Yes you can. Look for a fibre router.
Personally I use a TP Link TD-9980, but others use Asus and several other makes including BT HH5/6's.
HH5's can be got cheaply on ebay, or you can get a Hub 1 from PN but you will have to take another contract out.
markjonesx
DaveyH
Champion
Fixes: 12
That's a combined modem/router
Fixes: 393
@markjonesx , That model will work however it may be a bit limited in terms of performance. It only has Wireless N capability and it's wired ports are only 100Mb as opposed to Gigabit.
HairyMcbiker
All Star
Fixes: 21
The bit you need to look for is VDSL. That means it will accept the wire from the bt socket that currently goes into the white modem, Not a bad little router there. Missing the 5G band if you need that, if not then it would be fine.
markjonesx
I think I'll try the TP Link TD-9980.
Fixes: 393
This link http://forum.kitz.co.uk/index.php/topic,14436.0.html is a good starting place for info on combined VDSL modem/routers
HairyMcbiker
All Star
Fixes: 21
@MisterW According to the details on Amazon the ports are Gib.
Fixes: 393
@HairyMcbiker Not on the 9970 they aren't http://uk.tp-link.com/products/details/cat-15_TD-W9970.html#specifications . I've got one, but ONLY use it as a modem so it doesn't matter. The 9980 has Gigabit ports http://uk.tp-link.com/products/details/TD-W9980.html#specifications
HairyMcbiker
All Star
Fixes: 21
@MisterW
Interesting, as you can see here
a4cf86d8-4c2a-4c33-9cce-afa6502ec5b1
It says "Full Gigabit Ports". But it then says:
"4*10/100 Mbps RJ45 Ports, 1*RJ11 Port "
So some one has the details wrong.
I was going by the photo. But since s/he is replacing a Netgear it is probably only 10/100 anyway.
I know the 9980 is gigabit as I have been using one for past 2 years. But it is a lot dearer than this one.
ejs
Aspiring Hero
Fixes: 25
Do they even still sell the TD-W9980? It's "End of Life" in terms of support from TP-Link, and does not support vectoring.
HairyMcbiker
All Star
Fixes: 21
It may not, but my current speed is 71Mb, so no slouch.
If it is EOL then it is probably highly reduced in cost.
