Cable and connectors from Hub router to desktop PC
FIXED- Subscribe to RSS Feed
- My Router
- Re: Cable and connectors from Hub router to deskto...
16-07-2020 9:57 PM
Hi all. Just signed up to plusnet and while setting up discovered I need a longer cable to connect my desktop PC to the Hub One router. Can anyone tell me precisely what cable with what connectors I need? (More below on why this isn’t as stupid a question as it might appear).
I tried using a 5e ethernet cable that was until a few days ago used to connect a router (from my old ISP) to the wall socket microfilter. This seemed to fit the sockets in the Hub and PC, but I couldn’t connect, although WiFi was working fine. I noticed the connectors on this cable are different (narrower) to those on the cable supplied by plusnet. When I buy a longer cable, how do I make sure that the new one has the correct connectors? Googling around indicates that my old cable might have RJ11 connectors, while I need RJ11. I s this correct? 40 minutes on the phone to plusnet customer services got me nowhere.
Fixed! Go to the fix.
Re: Cable and connectors from Hub router to desktop PC
16-07-2020 10:33 PM
RJ11 is the cable between the filter and the DSL socket on the router.
RJ45 or ethernet should be used between your PC and the LAN port on the router.
Not sure what you are tring to but sounds like mixing the cables uo,
16-07-2020 10:36 PM
@InverL Welcome to the forum. 🙂
That's an ADSL/VDSL cable.
What you need is an ethernet patch cable like this:
https://www.run-it-direct.co.uk/cat5e-patch-leads/
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
16-07-2020 10:51 PM
Thanks both. I meant to say that I think the old one had RJ11 connectors, and what I need uses *RJ45* connectors. Your replies confirm this, thanks for the help.
16-07-2020 11:14 PM
Just for clarification: on the more recent faceplates, the DSL socket is wider than older ones, so an RJ11 to RJ45 cable is a better fit.
https://www.run-it-direct.co.uk/adsl-vdsl-patch-leads/
17-07-2020 12:12 AM
Thanks. I was also thinking of replacing the flat white microfilter-to-modem cable that plusnet sent with a shorter (better?) one. This seems to be what the cables in your link above would do, if I’m understanding you correctly. I’ll check to see if an RJ45 would fit my microfilter.
17-07-2020 9:47 AM
Sorry, my bad, I was mixing up this thread with another.
If you're using a microfilter, then those all have RJ11 DSL sockets.
Same link, but scroll down past the RJ45-RJ11s to the RJ11-RJ11s.
Good idea to replace the flat cable though. 🙂
- My Router
