I am experiencing problems with my CCTV's NVR and remote access.
The NVR is plugged into my hub with a lan cable and I access it remotely using an app called iDMSS lite to view the cameras whilst away from home
It has worked well for several months but now when I try to connect remotely it will not connect and I get a connection failed message.
I tried resetting or restarting the hub and this initially worked but then failed to reconnect the NVR, however if I remove the lan cable and plug it into another port the cameras instantly re connect and stay connected for a couple of days but then it fails to connect again and I have to swop ports again
Anyone got any ideas or suggestions please.
