By hub 6 bridge mode to work with Linksys?
- My Router
- By hub 6 bridge mode to work with Linksys?
20-06-2019 12:10 AM - edited 20-06-2019 12:10 AM
If not what are folks recommendations for a modem to work with my Linksys 3200? I have plusnet fibre and the one hub but also have a hub 6 hense the 1st question.
Regards Ryan
Re: By hub 6 bridge mode to work with Linksys?
20-06-2019 9:02 AM
modems could depend on your price range.
20-06-2019 9:25 AM
20-06-2019 9:45 AM
Modem options :-
Used BT HG612 from eBay - anything from £15 upwards
TPLINK W9970 ( looks awful but good modem performance ) about £30
Netgear DM200 about £30
Draytek 130 about £80
20-06-2019 9:46 AM
20-06-2019 9:58 AM
20-06-2019 10:18 AM
Why not just turn off the Hub One wireless and use the Linksys as an Access Point see https://www.linksys.com/us/support-article?articleNum=143751
Alternatively why not use the Smarthub in place of the Hub One, you may not need the Linksys.
20-06-2019 10:20 AM
The obvious minus for the BT modem is that it's used , with no guarantee. The plus is it's cheap!
TPLINK minus is it's looks! The pluses are 3 yr warranty and good modem performance. Cost is reasonable.
Netgear , better looking than TPLINK , not sure about performance, again reasonable cost.
Draytek , good spec but expensive.
20-06-2019 10:26 AM
Thank you again for the speedy responses guys.
20-06-2019 2:36 PM
If you have an ex BT HG612 (hopefully the 3B model, I have read reports of earlier versions overheating) it's possible to unlock it and extract detailed line statistics, see https://kitz.co.uk/routers/hg612unlock.htm
- My Router
