Bt home hub 6 ip address
- My Router
- Re: Bt home hub 6 ip address
04-11-2019 12:49 PM
Can I change the BT home hub 6 ip address from 192.168.1.254 to 192.168.1.1?
04-11-2019 1:00 PM
Moderators Note
This topic has been moved from Fibre to My Router
04-11-2019 2:42 PM
@Sean_Lavelle Welcome to the forum.
Yes you can change the IP address. You need to go to Advanced Settings / My Network / IPv4 Configuration to change it. Note that you need to save and as soon as you hit Save the page will freeze. This is because the IP address has changed. Get access back by entering the new IP address in your browser.
- My Router
