Brother printer won't connect to LAN
dleedlpt
Hi, just had a PlusNet router installed about an hour ago. Laptop is fine with the new LAN. Printer is not. Tried to print, realized it was offline. Pressed Wifi button. Clicked on 'set up wifi'.
It tried for a while then printed out a page of instructions I mostly do not understand at all.
Can anyone help this non-techie person? Thanks!
24 REPLIES 24
Fixes: 388
Re: Brother printer won't connect to LAN
@dleedlpt Could be that the printer has still got your previous routers details stored. I don't know Brother printers, but there should be instructions on how to clear its memory in the handbook.
Fixes: 585
@dleedlpt what model printer ?
@jab1 wonder if its a 2.4/5ghz problem ?
Fixes: 388
@MisterW But if has previously had other details entered...
Fixes: 585
@jab1
I'm assuming that
Deletes current settings, and puts the printer into searching for wifi networks... (might be wrong of course)
Ah! thinking about it , the printer is probably trying to use WPS
@dleedlpt did you press the WPS button on the Hub 2 ? Its on the back LHS
Fixes: 480
@dleedlpt
I've just looked at a manual, I've no idea if it's your model but this one has WPS set up.
Try pressing the WPS button on the left hand side of the hub, you should get a flashing blue light on the side. Then immediately go to the printer and press the WiFi button THREE times only.
Fixes: 480
Moderator's note:
Thread moved from Full Fibre To My Router
Fixes: 388
@MisterW wrote:
@jab1
I'm assuming that
When I have moved my CANON printer between Hubs/routers, I have had to carry out a manual reset procedure before using WPS to reconnect it.
dleedlpt
Thanks. I've done a reset (not the factory one) which seems to be the nearest thing.
dleedlpt
Thanks. It's an HL-L2340DW.
dleedlpt
Thanks, did that. Pressed the WPS button, got the flashing blue light, pressed the Wifi button on the printer 3x but all it did was invite me to 'set up wifi'. Tried again, same.
dleedlpt
I've done some sort of reset sequence on the printer. Not the 'factory' one.
Fixes: 388
@dleedlpt Do a full factory reset of the printer - you need to clear its internal memory of any previous settings/connections.
Check the manual - there is a section in there titled 'Reset Network Settings' - Follow that, switch the machine off   and back on again, and then retry the WPS setup,
Fixes: 585
That printer is only 2.4ghz WiFi. Try turning off the 5 GHz WiFi on the router, connecting the printer and then turning it back on
Fixes: 388
Hopefully, doing that with  the network reset should work.
