Broadband problems
Dkerr9024
Broadband problems
I just activated my router after having the engineer out a few days ago and my router/connection is very unstable and won't allow me to connect to the Internet for more than 2 minutes at a time.
YouTube seems to work, but any other site or app that I have cannot get connection.
When logging on my mobile it asks me to sign in, and takes me to a router management homepage. On this I've changed my password and then select the option "use router as is" and I appear to get connected. And while it shows as having a connection within 2 minutes nothing works and I have to do it all over again.
Any ideas on how to fix this or if its a problem with the router itself?
Tried phoning plusnet but can't get through to anyone in a call centre to discuss it at all.
1 REPLY 1
Fixes: 413
Re: Broadband problems
@Dkerr9024  Welcome to the forum.
Do a factory reset on the router by pushing a paperclip or similar in the reset hole. Keep the switch closed for 30 seconds. Leave it for 10 minutes to reboot.
If that fails then advise: Are the lights on the router changing?
Is this happening on just WiFi or also on a computer connected to the router via an Ethernet cable?
If you have a Plusnet Hub One and it's only a wireless problem have you tried splitting the two wireless bands and trying each in turn, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840 ?
