Broadband issues
Seanotray
Browser
Broadband issues
Hi all, first post looking for help, after recently joining Plusnet we are seeing connection issues on all devices except the fire tv which runs fine, laptops/I pads and I phones seem to have constant connection issues no matter where in the house, Iv also tried using a WiFi extended but that seems to cause more issues. The router is in the same place as the previous supplier and it caused no issues. Any help would be appreciated
Cheers sean
2 REPLIES 2
Fixes: 1,443
Re: Broadband issues
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,443
You could try splitting the 2.4 and 5GHz wifi bands,
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
