Broadband Performance Test
- My Router
- Broadband Performance Test
10-09-2024 11:12 AM
In trying to use the speed test option from the admin page for my Plusnet Router Hub 2 I get an error message about the connection is not secure (see attached screenshot).
Does any body else have the same problem?
Also should Plusnet issue an update to the router s/w to fix it?
Message 1 of 2
(759 Views)
1 REPLY 1
Re: Broadband Performance Test
10-09-2024 3:01 PM
Is your web browser up to date? The browser is complaining about the certificate required for a secure connection (it doesn’t recognise the issuer as trusted).
This problem has nothing to do with the router, the speed test is just a link to a website.
That's RPM to you!!
Message 2 of 2
(708 Views)
