Bridge mode
CShep
Bridge mode
I’ve purchase a mesh router system due to having so many wifi dead-spots in my house and I need to switch my plusnet router into a modem only mode. I’ve logged into the admin portal but can’t see a bridge mode setting. Does anyone know how I do this? All the posts I can find seem to be a few years old so I’m not sure if they are current or not. Many thanks
Tags (3)
8 REPLIES 8
DaveyH
Champion
Fixes: 12
Re: Bridge mode
You can't, the Plusnet Hub One doesn't support bridge mode.
Fixes: 418
Re: Bridge mode
@CShep
A good budget solution is to replace your hub with a model 3B Huawei HG312 modem from an auction site such as Ebay. They can be unlocked if you wish to monitor your dsl statistics
CShep
Re: Bridge mode
Thanks so much to both of you for your help. That helps answer that one!
@Baldrick1 Thanks very much for the suggestion of the alternative modem, I’ll take a look!
Fixes: 418
Re: Bridge mode
@CShep
Sorry there's a typo in my post it should read HG612.
CShep
Re: Bridge mode
Ah fab thanks I’ve just found it. Silly question, but if I replace my plusnet router with this modem, does that then need to be put into bridge mode or would this come in that set up (excuse my ignorance I’m not really sure of the difference between a router and a modem) thanks for ur help
Fixes: 418
Re: Bridge mode
@CShep
Unless it's been moded you don't need to do anything with it except plug it in and connect the DSL and WAN leads.
Very basically the modem converts the multi frequency broadband coming from the fibre cabinet back into a digital data stream. The router distributes that data to your connected devices.
CShep
Re: Bridge mode
Thank you so much! I’ll order one now. I really appreciate all of ur help, u r a star!
bill888
Champion
Fixes: 38
Re: Bridge mode
fwiw. List of bridge modem options
https://community.plus.net/t5/My-Router/What-is-a-suitable-VDSL-modem-for-ASUS-RT-AC86U/m-p/1737761#...
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
