Bridge mode
- My Router
- Bridge mode
Bridge mode
14-07-2020 8:30 PM
Re: Bridge mode
14-07-2020 9:21 PM
You can't, the Plusnet Hub One doesn't support bridge mode.
Re: Bridge mode
14-07-2020 9:42 PM
A good budget solution is to replace your hub with a model 3B Huawei HG312 modem from an auction site such as Ebay. They can be unlocked if you wish to monitor your dsl statistics
Re: Bridge mode
15-07-2020 8:32 AM
@Baldrick1 Thanks very much for the suggestion of the alternative modem, I’ll take a look!
Re: Bridge mode
15-07-2020 10:44 AM
Sorry there's a typo in my post it should read HG612.
Re: Bridge mode
15-07-2020 11:27 AM
Re: Bridge mode
15-07-2020 4:32 PM
Unless it's been moded you don't need to do anything with it except plug it in and connect the DSL and WAN leads.
Very basically the modem converts the multi frequency broadband coming from the fibre cabinet back into a digital data stream. The router distributes that data to your connected devices.
Re: Bridge mode
15-07-2020 6:21 PM
Re: Bridge mode
16-07-2020 6:30 AM
fwiw. List of bridge modem options
