Blocking a website Permanently?
- My Router
- Blocking a website Permanently?
08-01-2018 5:57 PM
Basically I want to block all access to a particular website on my home network
I can easily block the site on my own pc but i want to restrict access to the whole network
is this possible with the onehub?
Message 1 of 2
(475 Views)
1 REPLY 1
Re: Blocking a website Permanently?
08-01-2018 10:31 PM
I don't think the Hub One allows you to block websites.
A "third party" router that lets you use, say, Open DNS will enable this but you can't set your own DNS settings on the Hub One as I recall.
Message 2 of 2
(441 Views)
- My Router
