Better WiFi on a router
- My Router
- Better WiFi on a router
on
09-05-2020
7:07 PM
- last edited on
09-05-2020
7:23 PM
by
Hi
We have a Plusnet Hub One router which we've had for quite a few years now. We'd like a longer range to reach down the garden. Is it worth asking Plusnet of they have a router with a longer range or is there a compatible router from elsewhere which will work?
Moderators Note: Topic title changed after split
Re: Plusnet Hub One and BT Smart Hub 2
09-05-2020 7:21 PM
Moderators Note
This topic has been split from another topic.
Re: Better WiFi on a router
09-05-2020 7:25 PM
For something like you want to do you might want a repeater or mesh network.
10-05-2020 11:14 AM
I bought a Netgear EX2700 (about £20) and found that it worked all the way to my greenhouse at the end of the garden. The EX3700 is dual band and £10 more.
Other similar makes are available......
10-05-2020 11:16 AM - edited 10-05-2020 11:18 AM
If there's a shed down the garden with power, you could use a mains powerline extender which runs BB signal
through houses' electrical wires.
https://www.currys.co.uk/gbuk/computing-accessories/networking/powerline/tp-link-wpa4220-wifi-powerl...
