Better WiFi on a router
Osberto
Hi
We have a Plusnet Hub One router which we've had for quite a few years now.  We'd like a longer range to reach down the garden.  Is it worth asking Plusnet of they have a  router with a longer range or is there a compatible router from elsewhere which will work?
Moderators Note: Topic title changed after split
4 REPLIES 4
Fixes: 1,483
Re: Plusnet Hub One and BT Smart Hub 2
Moderators Note
This topic has been split from another topic.
Fixes: 1,483
Re: Better WiFi on a router
PN don’t have a better router.
For something like you want to do you might want a repeater or mesh network.
TeeGee
Seasoned Pro
I bought a Netgear EX2700 (about £20) and found that it worked all the way to my greenhouse at the end of the garden. The EX3700 is dual band and £10 more.
Other similar makes are available......
Gel
Aspiring Champion
Fixes: 29
