Best wireless mesh
Donovan2
Best wireless mesh
I have recently had Plusnet2 router installed but I do not get a good signal in parts of the house. Can anyone recommend the best wireless mesh to use with this router?
4 REPLIES 4
Fixes: 118
Re: Best wireless mesh
@Donovan2
Any chance of running ethernet cable around the house?
ExForce9
All Star
Fixes: 10
@Donovan2
No.
Mesh systems are expensive and don't work as well as cheaper WAPs (Wireless Access Points) connected via ethernet.
PowerLee
@Donovan2
I'm using a Fritz 7530 AX router & I added a Fritz 3000 AX repeater in a mesh configuration, I get excellent speed plus coverage throughout both floors of the house even without any wireless backhaul between the router downstairs & repeater upstairs.
No longer a Plusnet customer due to Openreach incompetence - Moved to Zen via CityFibre for symmetrical 500Mbps fibre broadband & digital voice.
RealAleMadrid
Fixes: 68
@PowerLee  Not sure what you mean, do you have wired ethernet backhaul or is this a typo and you meant to say no wired bachaul?
