Best way to bridge to office
Bazbop
I have recently moved and been connected to PN. Our spare bedroom/office has very poor signal from the router as the master socket is right at the front and bedroom at the rear. There is an Ethernet connection from where the router is to the office/bedroom and it works well as have plugged devices in but ideally I want to throw the WiFi signal upstairs using the Ethernet connection so multipul devices can be connected rather than messing about with cables all over the office. What would I need to do this?
2 REPLIES 2
Fixes: 118
Re: Best way to bridge to office
@Bazbop
If you have ethernet already in place to the office then all you need is a WiFi Access Point (WAP). Old routers can sometimes be used.
I'm sure others will recommended suitable WAP's.
Ian06
Fixes: 6
@Bazbop   See this thread Wi-Fi-extender-help  -  similar question / recommendations....
