BT homehub 6
- My Router
- Re: BT homehub 6
BT homehub 6
27-05-2021 1:41 PM
I have been using BT homehub quite reliably for over 6 months but recently it (assume) has become flaky with WiFi often showing no internet connection, happens with RJ45 as well
I have checked the hub and both network and internet show connected for last 6 days.
Is there anything else I can do to trace the issue? Plusnet say no disconnect their end
Message 1 of 3
(398 Views)
2 REPLIES 2
Re: BT homehub 6
27-05-2021 2:01 PM
If you lose the Ethernet connection then it's unlikely to be anything to do with WiFi so talking about that is irrelevant.
If you go in to the Advanced/Technical Log/Event Log and search through it will tell you whether it has rebooted and if so the reason. So the next time it happens have a look and post the results.
Message 2 of 3
(393 Views)
Re: BT homehub 6
27-05-2021 2:05 PM
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Message 3 of 3
(389 Views)
