BT homehub 6
Madhatter007
BT homehub 6
I have been using BT homehub quite reliably for over 6 months but recently it (assume) has become flaky with WiFi often showing no internet connection, happens with RJ45 as well
I have checked the hub and both network and internet show connected for last 6 days.
Is there anything else I can do to trace the issue? Plusnet say no disconnect their end
2 REPLIES 2
Fixes: 360
Re: BT homehub 6
@Madhatter007
If you lose the Ethernet connection then it's unlikely to be anything to do with WiFi so talking about that is irrelevant.
If you go in to the Advanced/Technical Log/Event Log and search through it will tell you whether it has rebooted and if so the reason. So the next time it happens have a look and post the results.
Strat
Fixes: 565
Re: BT homehub 6
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
