BT Smart Hub vs. TG582N
- My Router
- BT Smart Hub vs. TG582N
01-05-2019 9:30 AM
I have acquired a HH6. Without configuring it for Plusnet I powered it up in the same room as my TG582N and using Netgear's WiFi Analytics app tested the signal strength throughout my house. In the same room as the routers both routers gave approximately the same levels (just below -50dBm), but further away the HH6 slightly shaded the TG582N, until I went upstairs when the HH6 seemed to drop off more. The signal strength seemed to fluctuate more for the HH6.
Have I performed a valid comparison or do i need to fully configure the HH6 to sync my connection in order to get a meaningful comparison, particularly concerning the fluctuating signal strength?
Re: BT Smart Hub vs. TG582N
01-05-2019 9:53 AM
Is the TG 582 dual band? Did you test the two on the same channel? Have you separated the two bands on the Smarthub 6 in case the two bands being syncronised is confusing things? Did you try each band in turn on the Smarthub 6 (and the TG582 if it has this capabiliy) to see which is best?
Having the Smarthub 6 synchronised to the internet shouldn't make a difference but there are other issues to consider.
01-05-2019 10:23 AM
Thanks @Baldrick1 for your response - clearly more to think about.
The Tg582N is a single band (2.4 GHz) router, and since I hadn't done anything to the HH6 config and only saw 1 signal with its SSID in WiFi Analytics I'm assuming not split. Also, I don't know how the app deals with different frequency signals or indeed if the android tablet I used has dual band connectivity. So in essence my tests so far don't adequately test the HH6.
More fun and games to be had then.
