BT OPENREACH Master Socket V4
atann
I currently have the V2 faceplate. Would changing it to a V4 improve sync speed? Currently getting 61Mbps down 20Mbps up, Noise Margin 6-6.4dB ECI cabinet. Line attenuation 0dB Signal attenuation 0dB. Has anybody done this? Did you find any improvement?
2 REPLIES 2
Fixes: 1,552
Re: BT OPENREACH Master Socket V4
Does plugging your router into the test socket behind the faceplate increase the sync speed? If it doesn't I personally wouldn't see any benefit in replacing the faceplate.
atann
No it doesn’t.
