BT Hub 5 password issue
egeoffreydavies
Just a heads up for BT hub 5 users.
I had a power cut and due to changing my Plusnet password, the router would not reconnect. I changed the router password - but no joy. After much frustration, and a call from support ( who couldn't help other than to suggest using the original Plusnet router) it seems the BT router doesn't recognize the # symbol. After changing password again, using a different symbol, instant connection.
1 REPLY 1
Fixes: 251
Re: BT Hub 5 password issue
@bobpullen
Does the Plusnet Hub 1 (a cloaked BTHH5a) have the same characteristic?
