BT Hub 5 Type A with Plusnet ?
brockied
Hi There,
Been looking around the forums and see some people are using the BT Hub 5 with Plusnet. I am moving over from BT to Plusnet and have the BT Hub 5 Type A which I received from BT when I signed up, would this be locked to BT or can I use this on Plusnet as I don't see a username & password area in the settings. Thanks.
2 REPLIES 2
Mustrum
Fixes: 73
Re: BT Hub 5 Type A with Plusnet ?
Yes the HH5 can be used on PN, detailed instructions can be found on the ADSL and FTTC forums as stickies.
However, if you are unable to see the username and password then you may be better getting the PN router as they can be set up automatically.
brockied
Thanks for your help. Will give the BT Router a go as I just found on the forum someone who said once the Plusnet connection is enabled the username and password box becomes active so I can type in the details. Will see how this goes.
