BT Home Hub with PlusNet ADSL no connection
- My Router
- BT Home Hub with PlusNet ADSL no connection
01-12-2017 8:21 AM
I have read the many topics here re:PlusNet ADSL using BT Home Hub, but I cannot find any topics where BT Home Hub fails to connect to the Internet when re-booting the BT Home Hub with valid PlusNet login credentials on the BT Hub. Basically the Home Hub will not connect and continually flashes orange. Are there any additional ADSL settings I need to configure on the BT Home Hub for PlusNet ADSL?
Re: BT Home Hub with PlusNet ADSL no connection
01-12-2017 12:49 PM
01-12-2017 12:55 PM
Moderator's note:
Moved to the My Router board.
Forum Moderator and Customer
01-12-2017 4:05 PM
Welcome to the forum. Have you seen this and the following discussion:
https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1192234
Also, are you new to Plusnet? If so there is also the possibility that the connection has not been activated yet.
If you have a BT Smart Hub 6 that is also covered in later postings in the above topic.
01-12-2017 4:59 PM
01-12-2017 6:17 PM
Have you entered your Plusnet username correctly into the hub? eg. myname@plus.dsl.net
Otherwise, log into the Home Hub 5 and go to Advanced Settings -> Broadband -> Connection
What does it report for Downstream and Upstream ?
If no speeds are reported, check the phone/broadband cable to the hub.
If you do see Downstream and Upstream speeds, next go to Troubleshooting menu.
Then click on Event Log.
Post the most recent messages.
- My Router
