BT Home Hub 6 - firmware updates
garywood84
If I use a BT Home Hub 6 on my Plusnet account, is it possible to download firmware updates for the router? If so, how?
6 REPLIES 6
Fixes: 779
Re: BT Home Hub 6 - firmware updates
Hi @garywood84
Unfortunately we can’t arrange for the firmware in BT routers to be updated however from what I’ve read to happen I believe that BT will update the firmware automatically when one is available although I wouldn’t quote me on that.
LifeonMars
Fixes: 10
The Bt Smart Hub and BT Smart Hub2 both received the latest updates when connected to plusnet.
garywood84
@LifeonMars
Perfect - thanks mate. I may try and obtain a HH6 via ebay to provide an interim solution whilst we push Plusnet to find a proper resolution to this.
Fixes: 99
@garywood84
Why only an interim solution? The Smarthub 6 is superior to a Hub One, which under the ugly case is an old BT Home Hub 5a with tweeked firmware.
Don't waste your time with the Hub One. Plusnet is a budget ISP and this is reflected in the hardware that they supply.
garywood84
@Baldrick1
For four reasons, mainly.
First, because the Hub One has worked well for me for the last 3 years. I tried it as a temporary measure when my Netgear router broke, and intended it only to be until I got another Netgear device. But I found that it worked fine, and so I saved money on buying a new router.
Second, because using PN hardware is preferable if a fault arises, because it's definitely not my kit in that context.
Third, because the PN router doesn't have a BT logo on the front.
Fourth, and perhaps most importantly, because it's important that we still push Plusnet to find a resolution to this problem. It's affecting a lot of people, and if those of us who are able to switch to different kit stop pushing for a solution, those who can't do that for whatever reason can't make as big a fuss.
Out of interest, though why do you think the Home Hub 6 is superior?
Fixes: 99
@garywood84 wrote:
@Baldrick1
1. As far as I am aware it does not suffer from all the current Hub One wireless problems
2. See here for a comparison of wireless performance between the two:  https://www.businessdirect.bt.com/content/uni2/documentation/c6nx/bt_smart_hub_test_report.pdf
3. It does not suffer from the Hub One noise problems.
4. The case is far more attractive than the garish pink footed Hub One, I have no problem with the BT logo.
5. You can dim/switch off the bright blue light.
6. If you get a Business version you have more settings available. For example you can choose the DNS server to use.
I commend your determination to press Plusnet for a solution to whichever of the current Hub One problems you are seeking to get resolved and I wish you all the best with influencing Plusnet/BT (the core firmware is the same as is used on the HH5).
