BT Home Hub 6 Security Issue - Fails PCI DSS Scan?
- My Router
- BT Home Hub 6 Security Issue - Fails PCI DSS Scan?
- « Previous
- 1
- 2
- Next »
Re: BT Home Hub 6 Security Issue - Fails PCI DSS Scan?
20-10-2020 12:28 PM
Thanks Steve
Interesting development for anyone using a BT Smart router which is still supported by BT, i.e using BT Broadband services.
Been talking to Security Metrics this morning and it's an easy fix following their comments below:
20-10-2020 12:35 PM
Pretty well as we thought then. I don't think I'll be changing back, it took me ages to reset all the smart plugs 😄
Glad you've got it sorted.
Steve
20-10-2020 1:53 PM - edited 20-10-2020 1:57 PM
@cstyles98 wrote:
Thanks Steve
So to be clear, BT still support these routers by keeping the firmware up to date, so they are fine to use on a Plusnet service. You do not need to have a BT account.
- « Previous
- 1
- 2
- Next »
- My Router
