BT HUB set up on Plusnet
stef1989
I have a new BT Hub which a friend is giving me as he has his own already.
How do i set this up with my Plusnet account?
4 REPLIES 4
HarryB
Fixes: 256
Re: BT HUB set up on Plusnet
Hi @stef1989 This post from another customer should hopefully answer your questions on this Smiley
https://community.plus.net/t5/Fibre-Broadband/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1...
EDIT: Having said this, when you say a new BT Hub, are you referring to their new Smart Hub? Unfortunately I don't have experience with the BT Smart Hub, but I'd hope it's not much different from setting up their previous Hubs.
 Harry Beesley
stef1989
Yeah it's the new smart hub. Will try it in a few days when i get it.
SpendLessTime
Fixes: 86
@stef1989
There is a thread about the smart hub here  https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1349153
geekofbroadband
There are some issues with the Smart Hub at the moment, the 2G is a bit flaky always dropping, some people have said it has a rebooting issue and syncs lower than the HH5 an obviously if you connect it to Plusnet you wont be able to get firmware updates for it to fix it as i think you can only get them through BT.
