BT HUB set up on Plusnet
- My Router
- Re: BT HUB set up on Plusnet
23-08-2016 10:55 AM
I have a new BT Hub which a friend is giving me as he has his own already.
How do i set this up with my Plusnet account?
23-08-2016 11:00 AM - edited 23-08-2016 11:02 AM
Hi @stef1989 This post from another customer should hopefully answer your questions on this
EDIT: Having said this, when you say a new BT Hub, are you referring to their new Smart Hub? Unfortunately I don't have experience with the BT Smart Hub, but I'd hope it's not much different from setting up their previous Hubs.
23-08-2016 11:41 AM
Yeah it's the new smart hub. Will try it in a few days when i get it.
23-08-2016 12:23 PM
There is a thread about the smart hub here https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1349153
23-08-2016 12:54 PM
There are some issues with the Smart Hub at the moment, the 2G is a bit flaky always dropping, some people have said it has a rebooting issue and syncs lower than the HH5 an obviously if you connect it to Plusnet you wont be able to get firmware updates for it to fix it as i think you can only get them through BT.
- My Router
