BT ECI modem compatible?
- My Router
- BT ECI modem compatible?
on
22-02-2017
12:51 PM
- last edited on
22-02-2017
12:57 PM
by
Mav
Just checking that the modem I already have with BT fibre will be compatible with Plusnet when I switch; I've found it tricky to confirm that it's VDSL2 from Googling. It's an ECI B-Focus v-2Fub/r Rev B. I'm hoping the v-2 bit refers to VDSL2 but would appreciate it if anyone can confirm this. Thanks.
Moderator's note by Mike (Mav): Serial number and MAC removed from attachment.
Re: BT ECI modem compatible?
22-02-2017 1:04 PM
If it works on BT it will work with PN, they use the same equipment.
PN also do a BT HH5 equivalent, the Hub One, they are both combined VDSL modem/routers, if want a one box solution.
