BT Business Smart Hub versions
Tarik
Are there any differences between the versions of the business smart hubs.
I bid on an item on Ebay which was listed as Item Code: 088317 but I received a 088315
I want to use it on plusnet FTTC.  Any differences worth worrying about?
4 REPLIES 4
LifeonMars
Seasoned Pro
Fixes: 12
Re: BT Business Smart Hub versions
I believe any BT Smart Hub (6) version will work with FTTC and ADSL  with plus net or BT
The Business BT Smart Hub (6)  Version will also work but  just allows you to alter some extra settings in the  Home Hub Manager settings.
If you need FTTP then you need the hub version with the red sticker on the 4th port on  the rear (These are unusual to see  for sale on the For Sale websites but do pop up now and again )
see
https://community.plus.net/t5/My-Router/Smart-Hub-6-Variants-and-Performance/td-p/1504366
also see  around post 10  on wards
https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/td-p/1349153
(Attachment pic taken from google images)
Tarik
Thanks.  I had read those threads, but there doesn't seem to be a definitive answer.
Unfortunately the one I bought is shrink rapped so I can't open it to verify what it is.
Beneath the item code it says BTB EI/SI 1.0 (088315)
On the auction listing it shows :BTB EI FTTP 1.0 (but is a 088317)
Not sure what these mean but it could be that the item code on its own is not enough to determine whether it is FTTC or FTTP.
I think I am worrying over nothing as it will be a big improvement over the TGN router I  currently use.
LifeonMars
Seasoned Pro
Fixes: 12
As I said in my Post
Any Version will work if needed just for FTTC .
If it is the FTTP version with red sticker on 4th Port  and you want to hardwire then use ports 1 to 3.
LifeonMars
Seasoned Pro
Fixes: 12
Thanks,
To set up ,      see # 41 here
https://community.plus.net/t5/forums/v3_1/forumtopicpage/board-id/Broadband/page/3/thread-id/306720
Once set up the Smart Hub should automatically update  firmware and security updates in time.
