Are Hub One routers subject to replacement due to age?
Mr_Paul
All Star
Fixes: 13
Re: Are Hub One routers subject to replacement due to age?
@bmc
"Have a good look at Zen Internet - not only do they do both they have a highly regarded router which has a phone port.
If you would prefer to stay with PN for internet look at A&A for VOIP."
I concur with both statements.
A few months ago I moved from Plusnet FTTC to Zen via CityFibre and ported my telephone number to Andrews & Arnold. I found Zen's VOIP offfering to work out much more expensive than A&A's for our usage.
The instructions for setting up VOIP on the Fritz!Box router looked a little daunting at first, but were actually surprisingly easy. A&A's, (UK based), technical support telephone line were also very helpful with doing this.
Zen supply the Fritz!Box router with the RJ11 to BT socket adapter, so our corded phone plugs in to that, and the Fritz!Box router also has a DECT base station built in to it for our cordless phones.
