Anyone having their router forget their password?
- My Router
- Re: Anyone having their router forget their passwo...
29-06-2019 9:10 PM - edited 29-06-2019 9:11 PM
I am a recent joiner to plusnet. One of the first diffuclties I had was that at least once a day the router disconnected, and refused to reconnect to plusnet. Every time I could go and re-enter my password and reconnect manually. There are no problems with the connection while connected. I was previously on sky and had no problems of this sort. Plusnet sent me a new router, but the problem remains. The logs continue to show an authentication error after a disconnect. Is it normal for the router to not be capable of reconnecting on its own? Does it not store the password? This I find unaccepatble and would rather go back and pay etra to sky for proper econnection management.
Re: Anyone having their router forget their password?
30-06-2019 3:08 PM
Welcome to the forum.
It's not normal at all. It should reconnect without you having to re-enter your username or password.
A Plusnet staffer will no doubt be around tomorrow morning at the latest to look into this for you.
01-07-2019 9:21 AM
Hi there.
I'm sorry to see you're experiencing connection problems. Unfortunately it looks like your account didn't activate automatically following completion of your broadband order which is likely the cause for the issues you're experiencing.
I've activated your account now, can you factory reset your router by pushing a paperclip into the reset pinhole at the back for 20 seconds please? Once you've carried this out the issue should be resolved.
Let us know how it goes.
01-07-2019 9:44 PM - edited 01-07-2019 9:45 PM
That's good to know. I have reset the router. Hopefully everything will work perfectly from now on Maybe you can let me know if it all looks ok at your end.
Thanks a lot
02-07-2019 9:06 AM - edited 02-07-2019 9:06 AM
14-08-2019 8:53 AM
Hello,
Sorry to hijack the thread but figuired it was better than starting a new one! I am having exactly the same issue. I tried to contact plusnet support this morning but they seemed confused about the problem and ultimately couldn't help me...
I will try another agent later if needed, but @Gandalf is there any chance you could take a look at my account also for me please? I have the same problem as the OP and also I have noted that when I logon to my account, it says
"Your order is currently being processed.
See below for the next steps."
Even though I have been live with Plusnet for nearly 2 weeks
Many thanks if you are able to help!
14-08-2019 11:12 AM
Hi @Spud211
I'm sorry to see your account didn't activate automatically following completion of your broadband order and that you're having experiencing problems with getting online as a result. I've just activated your account now, can you factory reset your router using the pinhole at the back letting me know how it goes?
14-08-2019 11:15 AM
Many thanks, much appreciated. I just received the email confirmed its activated and my account looks better now, so I expect this will be sorted I will check when I get home and confirfm for you.
14-08-2019 11:38 AM
14-08-2019 6:42 PM
All looking good thanks - reset and it automatically picked up the credentials and connected. Many thanks
14-08-2019 6:54 PM
- My Router
