Amazon Fire TV connection problems and the 2704n router
dskaye1
After a number of Amazon Fire Stick replacements, all of which have had problems connecting to WiFi through my 2704n router, I have come to the conclusion that the router is the problem. Any advice how to proceed? Thank in anticipation.
9 REPLIES 9
RPMozley
Fixes: 6
Re: Amazon Fire TV connection problems and the 2704n router
What signal strength are you seeing on the stick? Sometimes simply rotating your router by 45 degrees can make a big difference (especially models with internal aerials).
That's RPM to you!!
Browni
Aspiring Hero
Fixes: 49
What exactly is the problem?
Is it an authentication problem where you can't login? Can't see the router to connect with? something else?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
dskaye1
I can see the router and get a full signal strength. I'm unable to login with my password.
dskaye1
I get full signal strength. The physical separation is about 1.5m with some DVDs in the way. Moving the DVDs makes no difference.
Fixes: 87
Sorry if it seems to be a silly question but you are using the wireless password not the router log in one aren't you?
dskaye1
Certainly am. And no issues of mistyping, case or even the correct password as it shows on the screen, has been checked within the router settings and has worked until something within the settings blocked the connection.
Fixes: 30
Hello @dskaye1
Sorry to hear you are experiencing problems with connecting your device to your WI-FI. Please could advise if you are experiencing the same issue with other devices? If not can you please try the stick on an alternative WI-FI source to rule out an issue with the device.
Please let us know how you get on.
 SammyM
dskaye1
All my other WiFi devices connect with no problem. I have put an old Huawei HG633 router from Talktalk on and it is working fine so far with all devices including the fire stick. Failures had all occurred within three days so I shall monitor this situation. If it is stable after a week I shall test the original fire stick (over 1 year old) to see if it Is, indeed, broken.
paul_blitz
Can you connect by pressing the wifi button on the router?
