Amazon Echo
- My Router
- Amazon Echo
Amazon Echo
29-11-2016 10:14 AM
Has anyone managed to get an Echo working with their Hub One?
Seems there are issues with the HomeHub range and the fixes that Amazon say to use for that aren't working with the Hub One, probably due to different DNS etc.
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=202094190
Ta
Re: Amazon Echo
29-11-2016 10:24 AM
It seems that the Amazon fix says turn Smart Setup off. Not sure that it is possible on the Hub One ?
Re: Amazon Echo
29-11-2016 10:42 AM
Grr. Looks like it will have to go back.
Re: Amazon Echo
29-11-2016 10:49 AM
or get a decent router...
Re: Amazon Echo
29-11-2016 11:02 AM
Re: Amazon Echo
29-11-2016 11:06 AM
Hi, I have an Echo and a Dot working on mine.
Did not do anything special to set them up.
Re: Amazon Echo
29-11-2016 11:25 AM
@dvorak You got ipv6 dissabled for link local etc?
I have trouble with some stuff even if it's only local
Re: Amazon Echo
29-11-2016 1:20 PM
Re: Amazon Echo
29-11-2016 1:25 PM - edited 29-11-2016 1:27 PM
Yes I did have safeguard on at first, I turned it off when I could not use Reddit app, but that was not the cause of the Reddit problem, I believe that I added the Dot after turning the safeguard off.
Actually my usage is not being tracked at all now, could that be linked to safeguard?
Re: Amazon Echo
29-11-2016 2:33 PM
While we’re on this subject of this product, for those that own one how smart is it really?
I know you can ask it questions, but what if you were to ask it something like “What are my Amazon book recommendations for today?” Does it actually know and reply or simply shrug it’s electronic shoulders. Or what about saying to it “Play the latest episode of The Grand Tour on my Fire TV.” Can it do that?
I would like one for myself if it was more functional than I suspect it is, but as I have already said, the fact that it listens all the time, means I distrust it.
Re: Amazon Echo
15-12-2016 8:43 AM
However it connects to the wifi fine on another WAP in the house so it's currently in different room to where I would ideally want it.
I'll have a play and get back to you on how useful it is Mook
Re: Amazon Echo
15-12-2016 9:06 AM
@dvorak - Yeah, I'd be really interested to see if it was as useful as implied. You could always buy the remote voice control for it, designed for the issue have. Only 19.99!
Re: Amazon Echo
18-12-2016 3:29 PM - edited 18-12-2016 11:47 PM
All the other suggested changes for subnet etc were fine and Echo connected to the internet.
