Alternative router
tigersb
Alternative router
Hi
I have been having issues with my wifi recently
A few times a day my connection will drop
Spoke to an advisor and after checking my line was OK she suggested that I may have too many devices connected
I probably have about 15 devices that include PlayStation Firestick,mobile phone,2 wifi extenders,doorbell camera,back door camera,3 TVs,ipad and tablet
Is there a better router I could get that can cope with multiple devices?
Currently have a hub 2 on full fibre
Any help would be appreciated
13 REPLIES 13
Fixes: 118
Re: Alternative router
@tigersb
Any chance of running some ethernet cable to a WiFi Access point (WAP)? Would reduce the number of devices connected to the router.
As regard to a new router have a look on eBay or CEX for a Fritz!Box! 7530 or 7530AX (this has WiFi6). I have a 7530 sitting on my coffee table waiting to be unpacked. Cost £35.
This is the router Zen Internet use and is well regarded.
Fixes: 585
15 devices shouldnt be a problem at all
but 2 wifi extenders my guess would be they are the probelm...
Fixes: 480
@tigersb
That’s not excessive for these hubs. What do you mean by connection dropping? Are the lights changing? If so, it’s got nothing to do with the number of connected devices.
Perhaps if you start again and fully explain what is happening it would help and we can maybe save you some money.
tigersb
Thanks for the reply
To give you an example,my wife was on her ipad when her wifi went down
I took a speed test on fast.com with a reading of 2 mbps
Five minutes later I did the same test and it was 150 mbps
I have disconnected all my tv's and my playstation from the WiFi but still the same problem
I have also factory reset the hub
Fixes: 480
@tigersb
You did not answer the question: Are the lights on your hub changing?
To determine whether this is a WiFi or network problem it is necessary to determine whether this slow down occurs with a wired connection. Do you have any wired devices that you can use to test with during a slow down?
Another check you can do is to use a WiFi sniffer app (I use WiFI Analyzer on an Android phone) to see if there are neighbours using the same WiFi channel. If so you can change the channel that you use in the Hub 2 advanced wireless settings.
tigersb
Hi
The lights on my hub and the full fibre box have not changed
Should have mentioned that I only got the full fibre two weeks ago but I have been experiencing this problem for longer with my previous Plusnet broadband
The reason I changed to full fibre was that I'd hoped the issue would be resolved
I changed the channel on my router with no sucesd
wakeman
Fixes: 4
Sadly on the Hub 2 you can't split the 2.4 and 5GHz Wi-Fi.
What you could try is turn off the 5GHz Wi-Fi on the Router leaving just the 2.4GHz working and see if that helps, but as someone else has mentioned it might be an issues with the 2 Wi-Fi extenders. You could temporary switch one of them off for awhile and see if that helps.
Fixes: 480
This reinforces the suggestion that this is purely a wireless problem. You mention 150Mbps, is that indicating that you are on the 145Mpbs service or are you on a faster service with normally limited wireless speed? Are you uploading much data?
With the need for two WiFi extenders I assume that you have a large property?
By far the best solution for larger properties is to replace the Plusnet hub with a multi unit mesh set up. Even better if the mesh satellites are interconnected using an Ethernet backhaul.
tigersb
My plan is Full Fibre 145
The wifi extenders are two travel routers that I use to hard wire two devices that don't have WiFi capabilities
bobpullen
Fixes: 331
To add some of my experience to the mix: I have > 30 Wi-Fi clients on my network in a moderately congested Wi-Fi environment and a Hub Two can cope fine with it. Whatever the cause, I don't think it's anything to do with the number of devices on the network.
Fixes: 480
@tigersb
I keep a long Ethernet cable for investigating this sort of problem. Terminated CAT5e or better ready terminated cable is not expensive https://www.amazon.co.uk/TBMax-Ethernet-Gigabit-Network-Connectors/dp/B085Q7R71G/ref=sr_1_6?crid=K2Q.... Temporarily string this between your router and devices with an Ethernet port that are currently using wireless and if the problem persists then you know that it's a wireless issue.
poweredbyveg
I would recommend the router I have just got, GL-iNet Flint 2.
http://rwrd.io/vjwlnu4?c
lazyd0g
I have a 7530 as my main router and another 7530 as a repeater ( got it extremely cheap ). Wi-Fi is great even with many devices although not as many as you!
