Adding Express VPN onto Router
Pedmeawe
Anyone know if I can add Express VPN onto Router please fairly new Router thanks
9 REPLIES 9
Fixes: 395
Re: Adding Express VPN onto Router
What model router ?
Pedmeawe
It doesn’t give a Model just One Hub
Pedmeawe
One Hub
DaveyH
Champion
Fixes: 12
If you mean a Plusnet supplied "Hub One" router, then no.
Pedmeawe
Thanks it says plus net One Hub
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 395
@Pedmeawe  in that case, I'm afraid, no you can't add a vpn to the router. If you want to use a vpn you would need to run a vpn client on your PC  or whatever othe device you are using.
gleneagles
Aspiring Legend
Fixes: 17
If you log into the expressvpn site you can check with them which routers their vpn can be installed on.
They did provide a list some months ago but on checking them out they were fairly pricey.
You also need to check that particular model would work with PN and how easy it is to set up
We are born into history and history is born into us.
Tridens
Express VPN support these routers i recomend Asus or DD-WRT
Asus
DD-WRT
D-Link
Linksys
Netgear
Sabai
Tomato
TP-Link
