Acer C933 Chromebook won't connect to Plusnet Hub One router
mikewhodges
I have just acquired an Acer C933 Chromebook, but it won't connect to my home Wifi.  After I enter the key it returns an error that says Failed to connect - unknown error.   It connects to my wireless network at work and works perfectly.  It will also connect to the old pre-Fibre Plusnet router that I still have (It's not in use, I just turned it on to see if the Chromebook would connect to it).  I have split the 2.4gHz and 5gHz bands and it won't connect to either of them.  I believe the router firmware is on the latest release (I've checked for an available update and found none, but I'm not with the router so can't confirm which version I currently have. I've done the obvious things like restarting the router.
I have seen in previous posts that this is a router problem.  This would fit with my other experiences: SONOS speakers that suddenly drop off the Wi-Fi and then reconnect and a Windows laptop that keeps connecting and saying there is no Internet access, when other devices are already using the Internet.
Can I resolve this problem and get a replacement router via this forum, or do I need to contact the Help Desk and raise a ticket?
8 REPLIES 8
Fixes: 393
Re: Acer C933 Chromebook won't connect to Plusnet Hub One router
Are there any nonalphanumeric characters in either the SSID and/or the password ? and are they quite long ? Some devices don't like this
If so try removing the characters and/or shortening them.
mikewhodges
Sorry for the delay in getting back. No, I don’t think this is the issue. Neither SSID nor the key contain special characters and both a 8 characters long.
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Router
mikewhodges
Thanks for moving this to a more appropriate place.
In a newer development, I have discovered that the chrome book will sometimes appear to connect to the WiFi, but claims there is no internet connection. I have an HP Windows 10 laptop which has started demonstrating the same behaviour, but intermittently. This happens even when other devices, such as SONOS and iPhones are successfully using the internet.
Fixes: 393
Are both the Chromebook and W10 laptop using the 5ghz network ? and are the other devices which are ok , using the 2.4ghz ?
mikewhodges
Unfortunately it’s a bit more complicated than that: our iPhones and iPad will connect to either band, the Laptop only sees the 2.4 band (due to the limited network card) and the Chromebook won’t connect satisfactorily to either.
Fixes: 1,600
Thanks for your post @mikewhodges
I've ordered a new router for you now, let us know how it goes once you've received it Smiley
Fixes: 393
Thanks, I was wondering if it was the problem being discussed here https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363/page/103 but it doesn't sound like it.
lets see if the router that @Gandalf has ordered sorts the problem.
