Access DSL-2704N detailed configuration - more than expert_user.html
FIXED- Subscribe to RSS Feed
- My Router
- Access DSL-2704N detailed configuration - more tha...
10-12-2016 7:35 PM
I would like to access my DSL-2704N router detailed configuration. I am able to access a more detailed configuration using http://192.168.1.254/expert_user.html which allows me to make changes to a number of additional settings. I would like to get access to other information such as iptables configuration, control of TR-069 etc.
I am already aware of this thread but it does not appear to offer a method of accessing the router using telnet or ssh or provide a web address for advanced configuration. I do not want to download a firmware version for a different router.
Does anyone know how I can do gain access?
Fixed! Go to the fix.
Re: Access DSL-2704N detailed configuration - more than expert_user.html
10-12-2016 7:43 PM
Access to the configuration can be done by downloading the config to a file, decrypting it, editing it then uploading the config file.
10-12-2016 11:17 PM
The lines you need for SSH are here, you need to go back a few pages which will explain how to login into ssh using an ipv6 type address.
11-12-2016 12:00 PM - edited 11-12-2016 10:25 PM
OK so it sounds as though the only way I am going to have fine control over the router config is saving the config to a file, decrypting it, modify the xml file and then load it back as a modified config. Can you point me in the right direction to decrypt the file in Linux ?
Ed: currently working my way through information here ...
The good news is I have managed to decode the config file, the bad news is I get connection refused when I try to ssh ...
when I try
ssh -l admin fe80::feaa:14ff:fe70:46ef%eth0
I get
ssh: connect to host fe80::feaa:14ff:fe70:46ef%eth0 port 22: Connection refused
12-12-2016 3:19 PM
How odd!
Works all good here... I think your best off posting in the other thread, Darsh or Matty123 might be able to help further.
~ $ ssh admin@fe80::46e9:ddff:fe01:0101%eth0 admin@fe80::46e9:ddff:fe01:0101%eth0's password: > sh BusyBox v1.17.2 (2014-11-18 11:38:02 CST) built-in shell (ash) Enter 'help' for a list of built-in commands. # exit > exit Bye bye. Have a nice day!!! Connection to fe80::46e9:ddff:fe01:0101%eth0 closed.
14-12-2016 11:50 PM - edited 15-12-2016 10:17 PM
It helps if you enter the ip address for your router rather than for you own ethernet interface !
Ed: so all the information is in one place
I used the following steps in order to access advanced settings:-
Save config using expert_user.html
In Management -> Settings -> Backup
select Backup Settings button (save the file default name backupsettings.conf)
For decrypting the config file
Ensure python is installed (use package manager for Linux distro)
Download decrypt-conf.py file from https://github.com/mattimustang/optus-sagemcom-fast-3864-hacks
Put the decrypt-conf.py in the same folder as the backupsettings.conf file
Run the decryption using (assume backupsettings.conf)
python decrypt-conf.py backupsettings.conf
This should create a file backupsettings.conf.txt
Edit the backupsettings.conf.txt with an editor and add
<X_BROADCOM_COM_AppCfg> <SshdCfg> <NetworkAccess>LAN</NetworkAccess> </SshdCfg> </X_BROADCOM_COM_AppCfg> <SshControl> <Enable>TRUE</Enable> <UserName>admin_ssh_username</UserName> <Password>admin_ssh_password</Password> </SshControl>
just above
</InternetGatewayDevice> </DslCpeConfig>
at the bottom of the file (updating admin_ssh_username and admin_ssh_password to suit).
Save and upload the modified config file using
In Management -> Settings -> Update
The router Mac address can be found using
Device Info -> Summary
If the Mac address for the router were 12:34:56:78:9A:BC this can be converted to IPv6 address
123456 FFFE 789ABC
Flip the 2^1 bit for the second digit of the Mac in this case 2 = 0010 -> 0000
so the IPv6 address is 1034:56FF:FE78:9ABC
Now you should be able to ssh to the router using
ssh -v admin_ssh_username@fe80::1234:56ff:fe78:9ABC%eth0
you should be prompted for a password, and should get a prompt
after entering the password, type
sh
should return a prompt
typing exit and return twice or Ctrl+d twice should exit the shell and close the ssh session.
Note: changing password with expert_user.html for some reason causes problems when converting the binary .conf file to xml
- My Router
