ASUS XT8 settings for Full Fibre ONT
barton3112
Hi all, can anyone help with the setting I require for my ASUS XT8 Router
I have used this before with Sky with no problems and have just changed to Plusnet today.
The Plusnet router does work and the new account is setup but I want to remove the plus net router and use the ASUS one on its own.
Any help would be really appreciated
3 REPLIES 3
Fixes: 585
Re: ASUS XT8 settings for Full Fibre ONT
@barton3112 you will need to change the WAN settings to PPPoE and enter your Plusnet username & password.
Details are here https://www.plus.net/help/broadband/broadband-connection-settings/ , use the section 'What settings should I use for a router connected to a BT Openreach modem' (the ONT is effectively a Fibre modem.
barton3112
Thanks for the reply, I will give it a try.
barton3112
Worked great thanks for the advice
