ASUS DSL-AC68U Settings
- My Router
- Re: ASUS DSL-AC68U Settings
07-02-2021 8:59 AM
I have just bought a second hand Asus dsl ac88u router which should arrive in the next few days it has been reset, Is there any links to help me with the setup.
Thanks Steve
07-02-2021 9:48 AM
Basic connection details are Here for connecting to internet if you have fibre 😀
07-02-2021 10:03 AM
Yes I do have fibre, I saw something about Asus Qis settings but I don't know to find it or use it.
07-02-2021 10:11 AM
How to use Asus Qis instructions Here
07-02-2021 11:37 AM
@zephyr4 Just a quick check, the title of the thread says DSL-AC68U but your opening post says DSL-AC88U is that a typo? Which model are you actually getting as they are very different.
The ASUS DSL-AC68U has a very bad reputation with possibly the worst VDSL2 modem chipset ever (manufactured by Mediatek). It does not work well with the BT Openreach line management system (DLM) leading to various problems such as high error rates giving lower speeds, connections dropping and your line ending up banded, that is capped at a low speed.☹️
Personally I would not even connect it to my line so it is entirely up to you if you decide to use it but I would be sending it back.
On the other hand the DSL-AC88U has the preferred Broadcom modem chipset and is an excellent modem/router.😊
07-02-2021 1:43 PM
Sorry about the mistake it is the ac88u I had the ac68 but it was an awful router slow speeds etc.
Thanks for the info Steve
12-02-2021 10:13 AM
Installed the dsl ac88u with QIS at first I tried with firefox and it would not work then I tried IE and it connected first time.
Steve
