ADSL HG612 3B and Netgear Orbi
Fixes: 11
Re: ADSL HG612 3B and Netgear Orbi
Hi @temujin
Further to @MisterW
Before you connect the two devices together change the IP Address on the router as if the both share the same IP Address you'll have a duplicate IP Address on the network which will confuse stuff.
Also when setting up the DHCP pool make sure the default gateway address is that of the BT modem. Personally I was have used 192.168.1.254 for the router but it really is an individual choice.
HTH.
Dan..
Fixes: 209
I don't think so! The BT modem is just that, a modem. The Asus is making the pppoe connection and must be the default gateway. The bt modem ip address is only there to allow connection to the gui
Fixes: 11
My duplicate IP Address point is valid is but yes I should have thought about who was making the PPPoE connection.
Silly me!
Dan
temujin
Thanks to all for your help, i followed seebee`s screenshots exactly and also reduced the DCHP pool to .200, gave HG612 IP address of .201 before connecting and we have "showtime". Connected ethernet cable from HG612 Lan2 to Asus router and can now access it`s web interface from my browser, so all good. 👍
Regards
