5g fail hub one
NottheMessiah
5g fail hub one
so after messing about trying to connect to my seperate 5ghz wireless that @Gandalf  set up for me, i have now disabled it, for two reasons, one it would not connect to it even after making sure password was correct and after trying several channels. two after changing the name of the 5g network i could connect to it, but without internet access! anyone experienced anything similar? also not saying gandalf did anything wrong as it was messing about before he split the bands!
3 REPLIES 3
NottheMessiah
Re: 5g fail hub one
just seen @bobpullen s thread detailing pretty much everything im experiencing now!
bobpullen
Fixes: 307
Re: 5g fail hub one
@NottheMessiah - try a reboot of the router. I've just pushed a software update to it that should hopefully help.
NottheMessiah
Re: 5g fail hub one
ive just had chance to reboot it and re enable the 5g, seems to be working so far will update later if anything dose or dose not happen! @bobpullen thank you !
