5Ghz WIFI Dropping out
- My Router
- 5Ghz WIFI Dropping out
05-06-2020 6:25 PM
Having problems with 5ghz wifi dropping out every few days and have to reset the router, I've seen a lot of post on this and seems to be a common problem.
my hub firmware is 4.7.5.1.83.8.263has this been fixed yet? is very annoying
tia marc
Message 1 of 3
(646 Views)
2 REPLIES 2
Re: 5Ghz WIFI Dropping out
05-06-2020 8:36 PM
Try giving the 5ghz channel a separate SSID name.
Message 2 of 3
(622 Views)
05-06-2020 8:52 PM
done that a couple of weeks ago ,also changed channels so I'm currently testing it with Wireless interface type changed to 802.11 a/n (up to 450 Mb/s)
and see if that makes any difference
Message 3 of 3
(616 Views)
