5GhZ on Hub keeps dropping out
probbins
Every few weeks something goes badly wrong with the 5Ghz channel on my hub - it stops working entirely (internet, not wifi signal), the entire hub has to be reset, 5ghz turned off etc before it works again. Is this an issue with the Hub itself?
2 REPLIES 2
Fixes: 365
Re: 5GhZ on Hub keeps dropping out
@probbins  Welcome to the forum.
I suggest that you add your complaint to this thread https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510
Fixes: 1,466
Moderators Note
This topic has been moved from ADSL Broadband to My Router
