5GHZ WiFi slower than 2GHZ
chillyelmo
Re: 5GHZ WiFi slower than 2GHZ
I'll try unplugging the answer phone to see if that helps
chillyelmo
I unplugged the phone but as I did so I inadvertently unplugged the router. It worked for a bit but I think that was because I had restarted the router as it steadily went back to not being reliable. The range isn't great and it keeps dropping out.
I have already bout an AC2600 router so I want to use it. What would be a suitable modem for use with this.
Would I need to bridge it to the Plusnet router?
chillyelmo
WiFi has dropped down to 30mgps again! Can I get some help please. The router us obviously [-Censored-], why can't you just let me use my own!?
Fixes: 730
@chillyelmo Sorry to hear that. You should be able to use your own router, that's perfectly fine. Just set it up using the details here: https://www.plus.net/help/broadband/broadband-connection-settings/
Fixes: 730
Although I’ve just realised that it doesn’t look like your router has a modem built in, so you’ll need to buy a fibre/VDSL modem to go behind the router because as far as I’m aware it’s not possible to put the Hub One into bridge mode.
chillyelmo
I've bought a modem to go with the router just waiting for it to arrive. Speeds have been even lower and it's really annoying so I've connected my laptop via ethernet cable and the speed is down to 50MBps so it might not be the WiFi after all!
Is there any reason I would be getting such low speeds via ethernet?
Do I need to a full test before setting up my own router because it looks like I'm still having issues
Fixes: 54
@chillyelmo,
If you're only getting 50Mbps through a wired connection then I'd suggest it's likely we'll have to go down the fault route I'm afraid. GEA line test doesn't show any issues (see below). It might be worth popping the router into the test socket to see if this up's the wired speed for you and rule out any internal wiring and once that's been done we can either progress for an engineer asap for you, or you can wait until your new kit has arrived.
 Joe
chillyelmo
Just ran a speed test via the test socket:
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps): 67.60
Upload Speed (Mbps) : 11.49
Ping Latency (ms): 35
Fixes: 284
Thanks for getting back to us @chillyelmo
Those speeds are closer to what we expect to see.
Can you confirm there was nothing running in the background and that your YouView box wasn't being used to watch or record the extra channels you get via your internet connection?
 Matthew Wheeler
chillyelmo
No I disconnected everything apart from the TV. Turned off the firewall and anti virus. Unplugged the nearby phone. The youview box wasn't recording anything. I'll run it again in the morning with everything off, I wish you had an option on the hub manager to disconnect connections.
chillyelmo
These are the results with absolutely everything disconnected
Download Speed (Mbps): 65.92
Upload Speed (Mbps) : 11.03
Ping Latency (ms): 36
Fixes: 35
Hi @chillyelmo as your throughput is less than your minimum guaranteed I'd advise raising this as a fault, if you let us know once done we'll pick it up for you.
Having checked the connection there's been a number of drops over the last 24 hrs (see below), can you advise if this is from your rebooting/ disconnecting the router?
 Lauren Barry
chillyelmo
Yes the drops would have been from me testing from the test socket. Is it worth me running another test as independent sites have clocked upload of 18 although the download is still roughly 60
Fixes: 730
Yeah it may be worth running a speed test from a third party site like http://www.thinkbroadband.com/speedtest
Let us know how your speeds look again.
chillyelmo
Turned everything off, Plugged into the test socket:
thinkbroadband: 68 download, 18.7 upload
BT Wholesale test 67 download, 11 up
