3rd party router cant connect
apashton
I've had a 3rd party router connected for 4 months or so, everything working fine, but last night it has just stopped connecting. I have plugged in the plusnet one and I'm now online, but if i try to switch to the 3rd party i cant connect again?
Do i need to change any settings or something? has there been a plusnet update to the settings to be able to connect?
Alex
3 REPLIES 3
Fixes: 398
Re: 3rd party router cant connect
@apashton  Welcome to the forum.
It's much much more likeley that an electrical surge in the night has either screwed up your router's settings or killed it altogether.
Have you tried a factory reset on it and tried setting it up again from scratch?
Tapin
Strangely enough mine just randomly stoped working today too exactly the same story.
apashton
Resetting everything did work, annoying but at least it's fixed!
