2740 router won't let me connect multiple devices
acecase
I have just bought some smart bulbs and plug to go with other household devices so now have over 12 connected devices. This seems to stop certain devices connecting so I now have lights which periodically don't work or phones and laptops which won't connect to the WiFi. It's very frustrating when working from home to have to constantly switch to 4G backup connection. Is there an alternative router which you might be able to send me which can handle more than 12 devices?
8 REPLIES 8
Legend
Fixes: 255
Re: 2740 router won't let me connect multiple devices
@acecase Welcome to the forums. Plusnet are unlikely to send you an alternative router, but for all-round better performance, and to solve this issue, spend £20-£25 on a BT HH6 router off eBay. These work with PN, and configuration/set-up details are documented on the 'My Router' board on this forum.
Fixes: 1,600
Thanks for your post @acecase and welcome to our Community Forums.
I'm sorry to see you're having issues connecting more than 12 devices to your router, this is unfortunately a limitation of the router. In the past for these instances, our products team have been happy to send an upgraded router so I've arranged this now and you should receive it within the next 3 to 5 working days.
I hope this helps.
Legend
Fixes: 255
You would prove me wrong, wouldn't you? 😀😉
Fixes: 1,600
@jab1 it's what I do best Tongue (Joking)
acecase
Thank you for your replies and for the new router. Great customer service ☺️
Fixes: 1,600
No problem at all @acecase
Let us know if there's further issues or anything else you'd need help with. Cheers
acecase
New router arrived today, easy setup, changed the SSID to match the old one so I didn't have to go round resetting my devices, and now everything is connected (16 devices!) Everything is working fine, I think possibly even faster than before but maybe that's just time of day. Thanks for sorting my problem.
Fixes: 1,600
Awesome! Looks good, not a problem @acecase
