2704n router will not display basic, advanced, help settings
rmn1949
Hi ... internet, wifi etc are all working fine. Connecting to the router displays the home summary page ok, but selecting any of basic, advanced or help tabs just hangs. The router is still operating ok as can access web pages, wifi. If I then click refresh, router shows line disconnected (it isn't) and reconnecting again shows the home summary page ok. Strange thing is this was working fine a while back and no config changes were made at that time. Power on/off hasn't helped. Any ideas?
Thanks, Roman
2 REPLIES 2
bill888
Champion
Fixes: 36
Re: 2704n router will not display basic, advanced, help settings
fwiw, which web browser are you using?
There are known issues using Safari btw.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
rmn1949
Doh ... works fine with Opera and Firefox. Thanks Bill.
Regards, Roman
