2704n router will not display basic, advanced, help settings
FIXED- Subscribe to RSS Feed
- My Router
- Re: 2704n router will not display basic, advanced,...
15-02-2017 10:55 AM
Hi ... internet, wifi etc are all working fine. Connecting to the router displays the home summary page ok, but selecting any of basic, advanced or help tabs just hangs. The router is still operating ok as can access web pages, wifi. If I then click refresh, router shows line disconnected (it isn't) and reconnecting again shows the home summary page ok. Strange thing is this was working fine a while back and no config changes were made at that time. Power on/off hasn't helped. Any ideas?
Thanks, Roman
Fixed! Go to the fix.
15-02-2017 4:08 PM
fwiw, which web browser are you using?
There are known issues using Safari btw.
Re: 2704n router will not display basic, advanced, help settings
15-02-2017 4:38 PM
Doh ... works fine with Opera and Firefox. Thanks Bill.
Regards, Roman
- My Router
